e36 m42 Catalytic vs e30 m42 Catalytic
  • series88
    • Nov 2011
    • 1231
    Does anyone know if these are swappable? A friend of mine let me use an e36 m42 cat to see if it will work for the e30. Any thoughts?
  • Vivek
    attention whore/retard/bitch
    • 6167
    Welding it should work just fine. Bolting it..get under there and compare them. If it looks like itll fit, try it.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • roguetoaster
      Biggus Tippus
      • 7819
      Can't be 100% here, but they ought to interchange at the connection to the manifold, but the rear flange will be the issue as length, angle and flange orientation are probably different.
      • series88
        • Nov 2011
        • 1231
        Thats what I'm thinking. I was looking at it and it.looked kinda diffent.
        it looks kind of different shape wise. Inlet from the down pipe comes from the side almost.
        Also, i forgot to mention, it came out of a ti. (if that matters)
        • roguetoaster
          Biggus Tippus
          • 7819
          Probably makes no difference if it came out of a compact or a sedan. The front section ought to be the same with the difference being made up in the back (where it is less expensive to alter).
          • series88
            • Nov 2011
            • 1231
            So granting i get it mounted, does anyone know if it will help me pass? Has anyone done this?
