Fan Shroud Removal
  • Threehz
    • 1480
    Fan Shroud Removal
    I was reading a how-to for replacing water pump and first step is to remove the fan shroud by unclipping it and pulling it up. The fan blocks it from being pulled up, in fact I saw no way to remove it without first removing the fan.
    Is there something I'm missing?
    Different strokes for different folks.
  • roguetoaster
    Biggus Tippus
    • 7830
    Just sort of squeeze the shroud to distort it enough to get it by the fan. A little force, take care not to damage the radiator core, and you should be okay.
    • Vivek
      attention whore/retard/bitch
      • 6167
      I've removed mine a couple times. It's easy to do, just kinda bend/angle it around the fan. I'm not sure of the exact process, but I would have remembered if it took more than a couple minutes.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • Threehz
        • 1480
        Thanks for clearing that up. I mostly didn't want to damage the fan blades.
