Brake booster hose routing?
  • SedanSandwich
    • Feb 2011
    • 314
    Hey everyone. I was wondering if someone has a diagram or picture of where the hoses off the brake booster should lead to. I know one goes to the lower intake manifold but the old line I pulled off had a funny looking T connection/valve that didn't have a part number on it and doesn't show up in real OEM.
  • roguetoaster
    Biggus Tippus
    • 7826
    The only connection to the booster if from the lower intake manifold, there shouldn't be a T fitting. The stock one looks like the one in the pic
    I would probably replace it if you have anything else as the PO probably had a tap for some vac actuated accessory or was checking vacuum with the fitting.
