M42 Lose Clutch
  • Learning
    • Feb 2011
    • 70
    M42 Lose Clutch
    When stepping on the clutch pedal, I feel there is a play or a gap that feels very lose before I feel the pressure. What could be the issue here?
    Thank you!
  • duleymane///iS
    • Jun 2012
    • 153
    Does the clutch still engage? If it does I say its the return spring on the clutch pedal. Look at it is right behind the clutch pedal. Push the pedal back and forth with your hand and watch the action of the spring.
    • Learning
      • Feb 2011
      • 70
      Yes, it still engages very well indeed. I will check the return spring and let you know.
      Is it difficult to replace the return spring? Or will I have to hire a mechanic to do it?
      • BraveUlysses
        • Jun 2007
        • 3781
        Is it a lateral (side to side) looseness? Pretty common for the pedal bushings to wear out.
        • Learning
          • Feb 2011
          • 70
          No, it isn't side to side. It's only when I depress the clutch pedal the first 1.5 inches feel very lose and then I feel the pressure. I could play with the first 1.5 inches by tapping it many times with my foot and it feels very lose. The other day, I heard a clicking sound once only (coming from the clutch pedal) when stepping on the clutch while driving, but it hasn't come back yet. I've been having this problem for about a month.
          • AndrewBird
            The Mad Scientist
            • 11898
            There is probably air in the system and it needs to be bled. Here is how:
