Let's talk about code 4E
  • MazterDizazter
    • 279
    Hey guys,
    My car has been idling like a bag of doo doo and hard to start when warmed up. I'm pulling code 4E which is coolant temp. sensor. I just replaced the sensor and flashed the code out. It came right back and low and behold, car still running like doo-doo.
    My first guess is that there could be an issue with the continuity in the wiring. Outside of that, I got nothin'. I have no access to a multimeter until tomorrow. Could something else be causing this code to trigger?
    1987 Toyota MR2: 20v blacktop screamer
    2013 Subaru BRZ: the new hotness
    1991 318is Alpine White: sold
    1989 325i Alpine White: sold
  • vpilarrt
    • Jun 2006
    • 2096
    The blue sensor (the one closest to the front of the engine) is the sensor for the ECM. Is that the one you changed?
    • MazterDizazter
      • 279
      Yes.
      • roguetoaster
        Biggus Tippus
        • 7830
        What reader were you using to pull that code? Perhaps the stomp test code would disagree with the reader?
        • MazterDizazter
          • 279
          The BavAuto reader. What is this "stomp test" you speak of? Or are you talking about matting the throttle?
          • roguetoaster
            Biggus Tippus
            • 7830
            The stomp test is simple, with the car off, turn the key to on, but don't start it, quickly press the throttle pedal to the floor 5 times. If that does not work you can key it up and actuate the throttle body by hand in the engine bay. Then the CEL with give a ~2/3 second solid blink and then give out the codes one digit at a time with a short pause in between each digit and a slightly longer pause between codes. When it has given all of the codes it will do the 2/3 second solid CEL. Then just look up the code.
            Or just search stomp test and find more clarity if that wasn't enough.
            • MazterDizazter
              • 279
              That makes sense. I will try that when I get home; thanks!!
