it wont pass smog high HC and unburned fuel smell
  • e30 vert
    • Jul 2012
    • 67
    hi
    i went to smog shop and it didnt pass the hc was high at 15mph test
    and at cold start i can smell unburned fuel out of tail pipe any suggestion ?
  • e30 vert
    • Jul 2012
    • 67
    any one?
    • mr ilia
      • May 2011
      • 582
      AFM or dirty injectors are the possibilities. Also incorrect spark plugs could be the reason too. Dead O2 sensor.
      A lot of things can be the reason for this type of issue.
      How does the car ride oaverall? Any issues? Is fuel ecomomy ok?
      • e30 vert
        • Jul 2012
        • 67
        im sure the injectors are clean and i just replace the spark plug with bosch super and
        clean the icv and it got worse now i can see little bit gray smokeish thing out of tail pipe
        the idle will go up to 2000 rpm and come back to 1500
