Updated injectors for M42
  • djmossm42
    • Jul 2012
    • 687
    Hello,
    I've been searching the forums/threads for options for updating my M42 injectors. I know people use 700, 710, and have even seen 556 mentioned but I came across these which are advertised as a direct upgrade for the 91-94 318i/iS. (0 280 156 013)
    http://www.fiveomotorsport.com/product-search/?v=16383
    Any thoughts/experience?
    While looking around I also found this very detailed spreadsheet with Bosch injector data.
    I found (0 280 158 107) and the specs are very close, but the resistance is 12 ohm as opposed to 15.3 ohm and the distance between o rings is 60.65 as opposed to 60.5 yet the overall length is the same 77. Need a mechanical drawing to see where the 0.15 shift is.
    Source
    http://adaptronic.com.au/forum/index.php?topic=2636.0
    My Car info:
    1991 318iC
    Questions:
    1. Does the engine management accept a range of impedance values (12-16) and adjust based on the actual resistance values?
    2. Did E30 M42s have different injectors than E36 M42s during the same time frame 91-94
    3. Is the diameter standard for all Bosch injectors? Don't want fuel leaks.
    4. What's the difference between EV1, EV6, etc. Is it just a generation label? Will EV14 work without having to upgrade engine management?
    Thanks,
    Bryon
    Sent from my SGH-T769
    Wheelwell
    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
    LED Bulb Thread
    R6 LED Review
  • mr ilia
    • May 2011
    • 582
    Too many questions here. Read the thread below.
    • djmossm42
      • Jul 2012
      • 687
      Sorry for all the questions, Just looking for some direct answers. I read through that thread prior to posting and ended up a littler more confused, but it looks as though the (0 280 150 556) is a close match in both form and function. If anyone can shed some light that would be very much appreciated.
      Wheelwell
      LED Bulb Thread
      R6 LED Review
      • vpilarrt
        • Jun 2006
        • 2096
        I've run the 19 lb/hr 4 pintle yellow Mustang (IIRC they're the 0 280 150 556) injectors in my M42 for 3-4 years with no issues. Does idle smoother but can't really tell if they give more power.
        • roguetoaster
          Biggus Tippus
          • 7830
          The general consensus seems to be that changing to 4 pintle injectors offers only a crypto upgrade and is not worth it. Same is true of going to slightly higher flowing injectors. If I were you I would spend the money on getting a set of stockers cleaned and matched.
          All of this is moot if you are upgrading the management or building the engine of course.
          • djmossm42
            • Jul 2012
            • 687
            Thanks for the feedback. Didn't expect much in terms of power, but was looking for smoother running and possibly a few more mpg.
            I won't be heavily modifying the engine but considering Mark D chip, and COP kit in addition to either having my stock injectors reconditioned and flow matched, or updating to the 556s.
            May even take a chance on the latest generation 107 injectors depending on what I find after some more research.
            Thanks again.
            Wheelwell
            LED Bulb Thread
            R6 LED Review
