Rattling noise with gas pedal
  • Merlin8
    • Apr 2013
    • 160
    I have a 1991 318i m42 and there is a rattling noise when the gas pedal is pressed and released at very low speeds, or at least that's the only time I can hear it. No idea whats going on here. Help appreciated.
  • roguetoaster
    Biggus Tippus
    • 7830
    Open the hood and actuate the throttle by hand and listen for the noise. If it's coming from the front of the engine you probably have a timing chain or tensioner issue.
    If it's not coming from the engine bay the next best possibilities are the throw out bearing in the transmission or a drive shaft/differential issue.
    • Merlin8
      • Apr 2013
      • 160
      definately coming from front of engine. i replaced the tensioner with the m44 tct 9k miles ago.
      • roguetoaster
        Biggus Tippus
        • 7830
        How about a video or audio clip of the noise? I would suggest other items, but they are just a shot in the dark without actually hearing it.
        • kwill22
          • Apr 2009
          • 962
          If it's engine related What RPM's does it happen at? Around 2.5-3k?
          DENY IGNORANCE!
          Schwarz 325-totaled
          brilliantrot 318i-daily
          Originally posted by mkcman17
          don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
          • Merlin8
            • Apr 2013
            • 160
            That's when it seems to go away.
            • kwill22
              • Apr 2009
              • 962
              What oil weight are you using?
              DENY IGNORANCE!
              Schwarz 325-totaled
              • Merlin8
                • Apr 2013
                • 160
                5 qts 10/40, 1 qt 10/30. The dealership put 5qts in and it really needs 6 and added the last qt on way home from palm springs since I was concerned about running low on oil. 10/30 was all the gas station had.
                • kwill22
                  • Apr 2009
                  • 962
                  M42 correct. Should take 5
                  DENY IGNORANCE!
                  Schwarz 325-totaled
                  • Merlin8
                    • Apr 2013
                    • 160
                    That right, but at 5 the oil level is just barely above the bottom line on the dip stick.
                    • Merlin8
                      • Apr 2013
                      • 160
                      Turns out the guide is broken and pieces where flying around making the chain loose and slapping around.
