M42 idle problems when cold
  • awsomebmw
    • Apr 2011
    • 12
    Again !!!!!! Cold has hot calgary alberta and this time the e30 is not enjoying it at all i will start on a day were it is above -10 so not to cold it will run fine until i hit the highway then it runs really rich and rpm jump around from 600-2000 and if i let go of the gas it stalls ok that was before but now it pretty cold outside like -27 to-35 and the e30 is just hating i don't blame it i would hate my self too trying to work properly at that kind of weather anyways what is going on i need help fyi i replaced top half of engine 7 months ago sll vacuum lines are fresh do to this problem and clean Maf , icv , throttlebody, the one day it was doing it i unplugged icv nothing changed unplugged maf raised rpm to 1200 and plugged it all back in car worked fine but problem is tho i brought the car into the shop so it was not cold no more i am trying to figure out whats exactly going on what test to do thanks ivan
  • Gerta
    • Sep 2009
    • 2119
    throttlebody heater? If you did the mess under the intake did you remove any of that stuff?
    Sweet Jesus -27 to -35 is cold.
    Parts Collector and Former Houndstooth interior junkie.
    • awsomebmw
      • Apr 2011
      • 12
      Yes replaced al that too
      • hachirokuae
        • Jul 2013
        • 24
        Put in Bosch 4 pintle injectors 0280155702. They can be found in older volvo models like 850
        • oldmann
          • 265
          Temp. related problems may be the coolant temp sensor (behind the oil filter housing) or the intake air temp. sensor.
          Or something I've ran into on Semi. trucks. The air filter will ice over when that cold.
          • jdt10768
            • Feb 2013
            • 484
            Got on highway, and drive the car South until problem subsides.
            Seriously, I think there is a TSB about this issue somewhere out there. Will look around
            • jdt10768
              • Feb 2013
              • 484
              http://www.youtube.com/watch?v=MTnB5X4lURk maybe
              • awsomebmw
                • Apr 2011
                • 12
                Injectors are fine i cleaned them out they inject umbrellas out of them so not worried about that . Behind the oil filter housing there is a oil pressure switch which is also replaced does anybody have a better than taking the maf
                Apart and adjusting the air valve to open more because the cars should be between 800-900 not 1000 and up . If i could i would move down south.
                • awsomebmw
                  • Apr 2011
                  • 12
                  Fyi good furl pressure fuel pump brand new fuel filter injectors cleaned. Tune up aswell i chipped the car but the problem was there before the chip there is somthing to with air fuel ratio as in when it runs crapy smells like raw gas from exhaust
                  • jntar
                    • 459
                    Does your check engine light work? Do a stomp test if it does. I've seen similar issues to this from a bad o2 sensor.
                    M42 turbo build.
                    http://www.r3vlimited.com/board/showthread.php?t=301330
                    • awsomebmw
                      • Apr 2011
                      • 12
                      It does work i plugged it in when i was at work and it said Maf sensor and o2 sensor bit i did the euro/states switch when take off the cover on the fire wall and depending if you have cats in the car you should plug in the connector and unplug it you don't vs versa i tried either way no changed but what it does apparently The m42 comes in 318is in Europe and America, there is no difference in the cars. It is almost identical in every way. However, there is one thing that is not the same. In Europe the 318is (usually) did not come with Catalytic Converters. In the US they do come with catalytic converters. And this is where the problem lies. If the car did not come with Catalytic converters the ECU reads what it needs to off the MAF sensor upon start up. If it has Cat Converters it needs to read the information off the O2 sensor as well as the MAF sensor upon start up to tell the ECU the Cat is warmed up properly. To take care of this problem BMW added one plug on the wire loom to either be connected therefore by passing having to read the O2 sensor and just use the MAF sensor, or its disconnected in which it needs to read the O2 sensor as well as the MAF.
                      • awsomebmw
                        • Apr 2011
                        • 12
                        Sorry the engine light works and i went to work and plugged it in "
                        • awsomebmw
                          • Apr 2011
                          • 12
                          Was it a problem in the cold ?
                          • jntar
                            • 459
                            My car would die on deceleration or sitting at idle. Rev up to 1500rpm up and down. It ended up being the o2 sensor. I do not have a catalytic converter and my plug you mentioned earlier is unplugged.
                            Try the stomp test and see if any code comes up.
                            M42 turbo build.
                            • awsomebmw
                              • Apr 2011
                              • 12
                              Was it a problem when cold ?
