Belt Tensioner Teeth M42 Help!
  • elbrack
    • Jul 2013
    • 176
    So was doing my belts, and it appears that on the main belt furthest in, the tensioner teeth are a bit chewed up, so it won't travel along them properly. How can I fix this? I need to get this belt off and the new one on.
    Thanks.
    It's this part, (not my car but same area)
  • bmwm42
    • 6300
    Loosen the bolt and move by hand etc
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • elbrack
      • Jul 2013
      • 176
      Will try and report back.
      • elbrack
        • Jul 2013
        • 176
        Well, that worked. :-) Now to find the tension measurements for each belt.
        • bmwm42
          • 6300
          Don't get to technical with the tension of the belts it anit rocket science
          • elbrack
            • Jul 2013
            • 176
            What would you say is tight enough then? I've got a belt tensioner tool that I use for my Jeep, so I'm not really used to doing them by feel.
            • roguetoaster
              Biggus Tippus
              • 7830
              When you can twist the belt not much more than 90 degrees in the middle of the longest section it ought to be tight enough.
              • elbrack
                • Jul 2013
                • 176
                Well this turned into a shitty job. The power steering tensioner teeth are all chewed up from when the previous owner or somebody chewed them up. Realized this when I was trying to loosen the tension more to get the belt back on. Got it on, but now can't get it tensioned, because the gear just spins.
                Any tips on how to get around this?
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  Stick a screwdriver between the pump and block, pry towards the drivers side and tighten the 13mm nut on top of the toothed adjuster to lock it down.
                  • elbrack
                    • Jul 2013
                    • 176
                    Thanks dude, got it there. Seems tight enough. What a PITA though. I'm going to replace that tensioner piece when I get a chance.
                    • I8UR911
                      • Jan 2013
                      • 260
                      Just replaced the toothed tensioner piece on my build. Best $ spent so far :-)
                      Sent from my SCH-I535 using Tapatalk
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Well worth the $10 or whatever the bracket/nut cost now. How much are the parts now anyway?
                        • I8UR911
                          • Jan 2013
                          • 260
                          I think it was less than $10
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            They strip very easily. Usually from people not loosening the pivot point bolt(s) and then forcing it.
                            • kwill22
                              • Apr 2009
                              • 962
                              Ye and after 20 years of heat cycles it doesn't take much if you don't loosen that nut first. I actually need to replace mine actually
                              DENY IGNORANCE!
                              Schwarz 325-totaled
                              brilliantrot 318i-daily
                              Originally posted by mkcman17
                              don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
