Rough idle + check engine light
  • roguetoaster
    Biggus Tippus
    • 7826
    I'd assume that you bumped something and created a vac leak. If this is the case I'd look at the dip stick seals and vac lines (if you moved them).
    If not, perhaps you have a bad connection at the AFM, TPS or charcoal canister vent valve. Pull back the wire connector boots and have a look.
