cooling problem help.
  • tuanhd9
    • Dec 2012
    • 12
    91 318is
    recently the car been temperature been hoovering around 3/4 on the temp gauge, this happen during normal city driving and on highway its abit over 1/2.
    -ive recently change a bad fan clutch.
    -recenty bleed and replace coolant.
    -coolant level is fine.
    but the car still runs hot at about 3/4 on the temp gauge.
    one thing i notice is that the passenger side radiator hose is only warm to touch well the drive side is fully hot, is there still and air bubble?
    any ideas?
    thanks in advance
  • ///digitalme
    • Dec 2009
    • 2088
    Originally posted by tuanhd9
    91 318is
    any ideas?
    thanks in advance
    thermostat ok?
    I have a similar issue I have replaced, coolant hoses, thermostat, water pump, temp sensor and bypassed the heatercore...my car still overheats only when idling for atleast 10 mins never gets too hot. I sourced it down to my radiator
    • Balleristic31
      • Aug 2009
      • 4198
      tighten the ground nut on the back of the cluster at the temp gauge.
      -NICK
