Coolant for M42?
  • elbrack
    • Jul 2013
    • 176
    Coolant for M42?
    Alright, this has probably been beat to death, but I need some opinions on coolants that are safe for use in the M42. Coolant is running a bit low and couldn't til in early morning light what was in it at the time, just that it was a bit low.
    I know the BMW stuff is safe, but man it's expensive. Other suggestions? I've read none can be mixed. How difficult is a flush?
    I've read bleeding nightmares for this radiator.
  • dnguyen1963
    • Nov 2011
    • 2651
    As long as the coolant is designed for aluminum engine, it should be okay to use. The color is just a dye and it should not affect your engine at all. Die hard fans will insist on BMW coolant. Trust me, BMW does not make ethylene glycol. They buy it from big chemical company just like everyone else.
    • Das Delfin
      • Sep 2014
      • 2293
      I did an extensive search on this last fall. I ended up going with Peak coolant you can mix with any types. Just make sure you flush it out at least once every two years, otherwise it will become gel-like and eat your car. Bleeding isn't hard if you use the top radiator hose to fill it up separate from your motor. ie attach the hose to the radiator and twist it up so you can pour coolant into the rad, then fill the motor thru the expansion tank, then fill the rad. I did this and bleeding took 5 mins. Also it's important to turn on your heater to full hot and full blast.
      • AndrewBird
        The Mad Scientist
        • 11898
        BMW coolant is only like $10 more a gallon. It's not that expensive, and you should only need to buy 2 gallons every few years.
        If you haven't flushed your system and don't know when it was last done, it probably needs doing. Bleeding isn't nearly as big a deal as people make it out to be.
        • elbrack
          • Jul 2013
          • 176
          I know the system was flushed within the last year. Looks like it's filled with BMW blue. I'll go grab a bottle and some distilled water. Hopefully the top off is all it needs. Still baffled how it dropped so much lower.
          • Bglad
            • Jul 2010
            • 562
            Pentosin Pentofrost...
            Thread/
            • roguetoaster
              Biggus Tippus
              • 7830
              Check for drips/trails below the radiator expansion tank (bad o-rings) or at the plastic water pipe under the intake.
              • jrobie79
                • Mar 2006
                • 2526
                anything as long as its phosphate and nitrate free...i think I have prestone in mine now
                1991 318i ---- 308K - retired
                • bmwm42
                  • 6300
                  zerox g05
                  Originally posted by bmwm42
                  PNW vulture pm me for parts
                  Strategic nw e30 command
                  • The White Guy
                    • Jul 2012
                    • 144
                    Evans waterless coolant, there I said it.
                    No pressure,no corrosion and it is a lifetime cooling fluid.
