M42 Squealing noise
    M42 Squealing noise
    hey guys,
    heres a video of the squealing noise.
    whenever its cold out (or my engine is cold) it squeals like this EVERYTIME i come to a stop. I usually dont drive my car very far at night so i havent really figured out if its because of the ambient temperature or the fact that my car is still cold. whenever i release the clutch and the engine idles back to 750rpm, it starts to squeal like this and will go away once i hit about 2.5k rpm. i noticed it got worse when i sprayed some belt lubricant (or whatever its called) on it, trying to remedy it.
    anyone know the cause? ive read it could be the belts/pulleys but im not sure.
    thanks
    1985 528e
    1991 325ix
    1992 318i Convertible
    "this question is kind of like asking: would you rather be ass raped by a gorrilla with lube on his dick or butt pounded by a prison inmate with size 14 shoes and no lube....?"
    Most likely a loose pulley or worn belt. I would check that your power steering pump and/or alternator brackets are not loose.
    Parts Collector and Former Houndstooth interior junkie.
      The video is private but from what you described it's a loose belt. My alternator belt get's loose every now and then and makes that noise.
      Give her a crank and you'll most likely be set!
        changed so its unlisted
        1985 528e
        1991 325ix
          My alternator belt did that on my m10. It was loose so I adjusted it and the sound went away. The alternator bushings were clapped out so I swapped in new ones a few weeks later.
            I had a simliar noise. I tightened the belts and also sprayed some 'belt dressing/belt conditioner" on the belts and pulleys. This is a tacky spray which gives the belts more traction. CRC makes it and you can find it at most auto part stores.
              I've noticed that when I spray the belt dressing on, it helps for maybe 1 drive, then it seems to get worse than before. It used to only squeal once at startup, but now it squeals almost everytime i come to an idle.
              1985 528e
              1991 325ix
                Mine just started to do this. I replaced the belts about a month ago and it was great. For the last few days it has made this noise when it's cold...
                I'd have to say it's quite annoying.
