Alternator help - plastic cover on rear? (91 318is)
  • smbstyle
    • Mar 2015
    • 24
    So I'm changing out the leaky oil filter housing gasket, and when removing the 2 wires going to the rear of the alternator, the plastic cover cracked (piece that attaches to the alternator itself). Does anyone know if this piece can be replaced without buying a new alternator? I can't find anything online. Any help would be much appreciated. Thanks.
    EDIT:
    Was able to locate it; part # 12311727383 for the black plastic cover if anyone needs it, and part # 12311727764 for the 2 nuts.
  • roguetoaster
    Biggus Tippus
    • 7830
    In case you want to find one in a junkyard instead of paying $18, all E30 318i/is, and all E36 318i/is/ti models ought to have the same part.
