URGENT: M42 Cooling System Help
    So I was replacing all the hoses in my cooling system and came across two hoses that I forgot where they connect to. Any help would be appreciated.
    The first is a thin hose connected onto the left side of the fuel rail. Where does that connect to?
    And the second is the one connected to the brake booster. Where does that hookup?
    Here's where I'm at overall:
    I'm willing to PayPal someone like $20 if they help me figure this out within an hour.
    1987 325 Turbo
    First hose goes to a nipple on the bottom left of the throttle body (when looking at it straight on, same side as tps). Booster hose goes into a nipple on the lower intake manifold to the right of the throttle body (visible even when the upper manifold is bolted on. You can see it shining ever so slightly in you last pic)
    -NICK
