Oil distribution block
  • Rainydays
    • Jun 2013
    • 145
    I want to install an electric oil pressure sender using a fitting where the stock switch is by the oil filter housing. I also want to be able to keep the stock switch.
    I'm thinking of using either something like the TRM fitting, or using a remote distribution block. Ideally I'd want something like this which uses a banjo bolt and has the connections go out the side, but I can't seem to find anyone who's selling them anymore.
    My questions are:
    -Will the TRM fitting fit in that spot with the stock switch connected, or is it too long? Is there a shorter fitting that will work?
    - Where would I mount a remote block?
    - Does anyone still make that fitting that I can't find, or will one of you sell me one?
  • ahlem
    • 369
    Portcityracing.com has lots of fittings.
    You need to carefully identify the threads so you don't screw something up.
    There is a company called Longacre that has remote oil pressure kits.
