Code 1222
  • sketchkid
    • Dec 2015
    • 165
    Code 1222
    Ok so today I did my first stomp test and got a code 1222 and I'm thinking vacuum leak or fuel pump here is a video below tell me you guys thoughts
    Sorry, we couldn’t find that page
    91 318is "under construction"
    2007 328i - daily
  • Gerta
    • Sep 2009
    • 2119
    Clogged fuel filter?
    Parts Collector and Former Houndstooth interior junkie.
    • Gerta
      • Sep 2009
      • 2119
      OP - Check Here: http://www.verrill.com/car/e30_faultcodes.shtml
      1222 Lambda Control 1 This code is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds. Possible causes: Fuel tank ran empty, Incorrect Fuel Pressure, Injector valve defective or coked, Engine Temperature Sensor defective, Secondary air leak, Fuel evaporation control system defective, Air Flow Meter defective and/or the combustion is being disturbed by mechanical failure (Spark plugs, compression, intake/exhaust valves, ...etc.)
      I'd check for vacuum leaks first, clogged fuel filter second, then check sparkplugs, FPR, and fuel rail next. If all those are good, then it is a good possibility that the fuel pump is bad. You can check part numbers on Realoem.com and then hit up Blunttech.com for great prices.
      I recently resolved this code and it was a clogged line.
      • sketchkid
        • Dec 2015
        • 165
        I forgot to add I just did a new fuel filter, plug wire and sparks, air filter and clean ICV I do know I have exchaust leak. It was parked for years also I drain old fuel when replacing new fuel filter
        2007 328i - daily
        • vpilarrt
          • Jun 2006
          • 2096
          I'd take out the fuel pump and look inside the gas tank - could be full of rust.
          • sketchkid
            • Dec 2015
            • 165
            Will try to do overweekend
            2007 328i - daily
            • Gerta
              • Sep 2009
              • 2119
              Remember: No smoking.
              • sketchkid
                • Dec 2015
                • 165
                lol yea naw i don't smoke
                2007 328i - daily
                • formyhealth
                  • May 2016
                  • 217
                  I'll bet a dollar to a donut that it's your fuel pump/clogged fuel filter. Mine did the same exact thing and when I swapped the fuel pump with a Walboro unit it now runs like a top.
