Car has about 220,000 miles on it, I purchased it about 4 months ago and put on about 500 miles. The gauge read 3/4 about 2 weeks ago and found the tstat faulty and a/c fan resistor faulty. It ran fine for about a week and now back to the 3/4 mark. I work at the local bmw dealership which is a plus and had one cert tech do the repairs.
It could possibly be the tech didn't bled the system well enough or could be another component. I'll have him remove the cluster and check the ground nut as well. Driving today I did notice the temp gauge needle jump side to side quickly as I was about to die out. That was new to me. I'm sure the tech will look it through again, but any ideas where I should look? read the temp off the radiator? Check the water pump? Check the tstat again? Check for proper bleeding?
