M42 after MUI issues
  • sketchkid
    • Dec 2015
    • 165
    Hey everyone video of my new issues today can someone please help
    Sorry, we couldn’t find that page
    91 318is "under construction"
    2007 328i - daily
  • Balleristic31
    • Aug 2009
    • 4198
    Sounds like you have a massive vacuum leak.
    As for the squeak, if you changed coolant hoses and got a bit on the belts that would cause the squeak. Don't worry about that it'll dry out.
    Is the intake boot new? If so make sure that the plug is installed on the bottom side towards the throttle body.
    -NICK
    • sketchkid
      • Dec 2015
      • 165
      COOL, THNX! i'll recheck my vacuum lines again, also the boot is brand new i'll make shit the bottom is plugged to right location.
      2007 328i - daily
      • roguetoaster
        Biggus Tippus
        • 7796
        Was that a backfire I heard? If so, did you have the plug wires off?
        Where are the clamps for the intake boot? Am I seeing a missing nut above the brake booster port? Is your TB adjusted/closed at zero throttle (the cable looks wonky)? FPR vacuum line hooked up?
        Injector o-rings replaced?
