Throttle housing with fused gasket?
  • jaredmac11
    • Sep 2007
    • 253
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
    I opened up the throttle housing as Im tearing down my M42 and I noticed that either this is some kind of glued gasket or the original gasket was fused?
    The picture doesnt look it, but I cant tell if this was ever a true gasket. It's almsot flush against the face of the throttle housing. Im not even sure theres anything to scrape off.
    RealOEM shows it as a separate gasket, but I dont even see how this was ever even a gasket.
    do I need to somehow scrape this clean or can I throw another gasket on top of this?
  • oldmann
    • 265
    Scrape all that off, may not be much on the manifold, but get it off.
    Sent from my SM-G900P using Tapatalk
    • roguetoaster
      Biggus Tippus
      • 7829
      It's a thin metal gasket which crushes when installed.
      • jaredmac11
        • Sep 2007
        • 253
        Whats the best way to get it off? Im afraid of tanking a razor to it and making fine gouges all over the throttle body. I've heard that there are some fittings to put on a drill, but others are saying that could blow fine particles everywhere...
        Im at a loss. Its certainly not easy to remove.
        • roguetoaster
          Biggus Tippus
          • 7829
          Go ahead and use a razor blade on it, after all, it's not a cylinder head.
          If you do end up gouging it badly you can always carefully fill it/compensate with RTV.
          When you finish I'd be interested to know if that's two gaskets or one that separated.
