What kind of crankshaft bearing shells do I need to use for an engine with 80kish miles. I spun 4/5 bearings, lucky me no damage. What is the difference in kinds? Thanks.
Which M42 Crankshaft bearing shells?
You should hit up steve@BluntTech.com. He can advise you what you should get and what the costs should be.
If you spun a bearing, are you having the block/crank/caps checked by a machinist? You may need different thicknesses (i.e. colors) depending on any necessary repair. If you are confident that you have no damage with the spun bearing, then simply buying stock will be your answer.
All of this of course assumes that you have a stock motor ...Parts Collector and Former Houndstooth interior junkie.
