Clutch install, any while you're in there parts?
  • gespinal0301
    • Jan 2011
    • 317
    Hey guys, my clutch is slipping like crazy so I'm going to replace it at some point in the future. I'm going with a sachs kit from FCP that has the alignment tool, clutch disk, pressure plate, pilot & throwout bearing.
    I wanted to know if there's any while you're in there parts I should replace, I already want to throw in ssk, but just to make sure I don't miss anything that's easy to access while I'm in there, thanks guys!
    My Daily Driven 318is
  • 5Toes
    • 9836
    the dual mass flywheels wear out on these cars with higher miles, and they tend to clunk pretty bad when they do go. If you a performance oriented guy pick up a 7lb RHD engineering flywheel. They are super high quality and arrive fast from the manufacturer only costing $250.
    If you havent already a short shifter kit would be icing on the cake while you are in there. Buy a new bitch clip and the delrin rear mount for the shifter carrier arm along with the new shift lever and shifter cup bushing (its white).
    If the rear main seal isnt leaking just leave it alone in my opinion.
    good luck! redline MTL for your transmission would be a wise idea too
    • gespinal0301
      • Jan 2011
      • 317
      I've heard mixed things about a light flywheel for the m42, I live in Florida so I need A/C, but I've heard that with the A/C on during idle it seems to make the engine vibrate like crazy.
      For the ssk I'm thinking of using understeer.com since their price is pretty cheap, but I'm not sure if they are still active
      • kronus
        • Apr 2008
        • 13029
        you should replace the clutch fork pivot pin
        cars beep boop
        • 5Toes
          • 9836
          ^ good call. forgot to mention that! I have a bronze one in mine it was spendy but is a nice piece. SS clutch line too that makes the pedal so hard :) you'll love it hahaha
          understeer.com kits just use OE BMW parts. you can order the shift lever you want from ecs tuning or blunttech or anyone that has access to OE BMW parts. the z-3 1.9 lever is a nice OE+ feeling lever. you wont ever look back
          • gespinal0301
            • Jan 2011
            • 317
            Been reading about that as well, I already have the SS line so I'm already enjoying the stiffness lmao
            Most places I look at seem to be a bit more expensive then getting it from understeer, but I'll start putting everything together.
            So it looks like I have everything for the most part then
            • iPee
              • Nov 2013
              • 190
              Which stainless lines did you end up going with?
              • gespinal0301
                • Jan 2011
                • 317
                I got a UUC stainless line
                • hamann318is
                  • 3382
                  I'm planning on the M20 flywheel with only a pound or two shaved for clearance - I'm hoping that gets me some of the lightweight benefits without all of the racket. Might be something for you to consider if you still want that kind of upgrade.
                  The BMW 318 is back. With a vengeance.
                  • CanadianDirty30
                    • Sep 2015
                    • 173
                    I second this! the z3 1.9 lever is the way to go. got mine from garagistic along with new shift bushings, bitch clip, and shift cup. Made it so much tighter.
                    91' 318is Brilliantrot
                    Yes, it still has an m42
                    • gespinal0301
                      • Jan 2011
                      • 317
                      The more I started reading about flywheels, the more I'm leaning towards a RHD light flywheel lol. They make it seem like having a light flywheel is not that much of an issue and it's slowly convincing me to spend my moneyyyyzzz :devil::devil:
                      Right now my shifter just kind of goes in without any complaints, driving my brother's vert that has 50k less miles than mine feels amazing. I'm looking forward to what it feels like when I have the SSK in
