After swapping a g240 transmission because of a bad 2nd gear ive run into nothing but problems with starters.
The pin on the bellhouse of the new transmission (seen here):
is bigger than the hole on the top of my starter. on my original starter I decided the bore out the hole so it fit over the pin, and that worked to get the starter on, but it makes a horrendous sound when starting (heard here):
so I assume that its not where its supposed to be and something is wrong.
after ordering a new refurbished starter and having the same issue I decided that maybe I could force it over the pin. Bad idea. A few hammer taps later and the hoop on the starter broke off.
So, mostly I'm confused, and not really sure what to do. Has anyone experienced this before?
