m40 engine raise with e28 mounts
  • iKarolis
    • Feb 2015
    • 10
    Hey,
    I want to raise my m40 a little bit, because oil pan is few cm above the ground. And i recently smashed 2 of them. So i found out that e28 mounts could help me, but no clue from which e28 model i should get those mounts.. Can someone help me to choose?
  • roguetoaster
    • 7774
    Any 6 cylinder mounts are typically the ones used for M42s.
    Just be wary of changing engine height too much or you risk changing driveline angles and creating wear issues.
