E30 M42 - No Start
  • tremblay
    • Jan 2018
    • 1
    E30 M42 - No Start
    Hi all
    I have a 91 BMW 312is with an M42 (Parts car)
    Has not been run in a few years, trying to get it going.
    Engine Cranks very well
    Engine Sparks very well
    Fuel Pump makes flow while cranking (removed pressure line and placed in a bucket)
    Engine starts with a spray of ether in the throttle body ...
    Pulled a plug and the injectors do not seem to be firing... Dry as a bone, no fuel smell
    #1 - I will be removing the intake manifold to check for voltage at the injectors.
    Is it worth it to check fuel pressure? I know it is flowing while cranking, but it does not try to fire at all.
    Any other suggestions besides checking for voltage at the injectors?
    I have read this thread already - https://www.r3vlimited.com/board/sho...d.php?t=225575
    I dont think this is my problem because I have fuel flow...
    Any other suggestions? I will be checking injector voltage tomorrow.
  • e30sh
    • Apr 2015
    • 618
    Assuming you have fuel pressure / voltage at the rail, I've had good luck getting injectors unstuck with a soft tap. Use a brass drift or something that want damage the injector. Hit the metal part of the injector, not the plastic.
    Good luck.
