M42: Car Bogs between 3-4K RPM
  • Denso
    • Apr 2006
    • 9
    So my car bogs between 3-4 RPM. Just as I'm about to shift. It idles fine and runs fine at speed, but only when i accelerate and about to change gears does it bog. Any help would be appreciate.
    Thanks!
  • M42
    • Oct 2006
    • 32
    These motors are finicky about spark plugs . I would install some NGK BKR6EK .
    That helped mine when it had symptoms like yours. Could be AFM also but I would start with some plugs.
    Good Luck
    • dude8383
      • Jan 2005
      • 10387
      Good Luck
      That AND, get yourself some new wires.
      I had this same exact issue sometime ago and it turned out to be plugs and wires!
      • wastedincome
        • Aug 2004
        • 906
        +1
        I had the same issue's and finally saw the problem one night in the dark w/ the hood open. I could actually SEE the spark travel through the wires. Another item that should be replace while your in that area is the valve cover gasket's. When I changed my plugs I found some oil the around the top of the plug.
        Wastedincome420@yahoo.com
        CURRENT STOCK LIST:
        00' e38 750iL HighLine=Highway Queen
        92' e30 318 vert=Aint going anywhere
        91' e34 535iM=Aint going anywhere
        91' e34 525iA=For parts
        92' e34 535iA=For parts
