Tried AFM first, no difference.
The car starts up fine in 3-5 cranks. Then I put a little load on the engine to start moving then it seems as I get a huge drop in fuel pressure and the engine struggles big time...if I let off the gas and go to neutral, the idle will be 550-650RPM, I have to rev it out and it'll be stable at 750-800RPM.. (already cleaned the ISV).
To recap what I've checked, i made sure all the hoses didnt have any "hissing", checked all my intake manifold bolts and made sure everything was plugged in. I replaced my o2 sensor, tried another buddy's M42 AFM. The fuel pump and relay are both a year old. Fuel filter, plugs, wires, are also within 1-2yrs old..I pulled all the plugs, the center 2 plugs have a lil oil on them so I retorqued the valve cover bolts again. All the vacuum lines are new as well.
Other than that, I am lost.
