M42 reliability and high mileage
  • Vicarious
    • 223
    Hey guys, i'm shopping for an M42 318, and i've seen some for very good prices, but they have high miles, as in 200-230k. The owners say they've replaced a lot of stuff, like water/fuel pumps, t-stats, radiators, etc, all that preventive maintenance goodness. Now i know that the M42 has forged internals and is one of the strongest engines, but how strong. Should i stray away from the ones with 200+k miles?
  • e30_kid89
    • Apr 2006
    • 489
    around that mileage, i would automaitcally consider that the timing chain,rail,guides etc and tensioners will all need to be overhaule'd. also check the oil sump becauce they are know for falling out and sitting in the lower oil pan leading to engne destruction.
    • Vicarious
      • 223
      how much do you think that stuff will run me? From what i've read those things can be done by ones self easily.
      • jrobie79
        • Mar 2006
        • 2525
        how hard is it to change the timing chain by myself? and whats the cost of a new one. my car is 222K on it i bought it with 180 so im thinkin about taking a look at some of the stuff u mentioned.
        1991 318i ---- 308K - retired
        • BrandC
          • Jul 2006
          • 444
          Brendan Percel's (spelling?) webpage is the most excellent 318i/is resource. It is filled with DIY's for anybody decently mechanically inclined. He also rates the difficulty levels of tasks like Pelican Parts DIY's.
          The M42 is a very easy engine to work on, you will have fun doing the work yourself.
          -Brandon
          • jrobie79
            • Mar 2006
            • 2525
            whats the URL for that site?
            • Funkmasta
              • May 2004
              • 7185
              If you find a motor with that mileage, don't immediately discount it.
              I just this weekend, saw a nearly 300k non-rebuilt M42 just lay down 220-190 in every cylinder.
              Joe Funk -- Portland Oregon
              That Guy.
              03 X5. 3 liter obviously.
              • frost_dxb
                • 40
                300k is just mid life they are strong engines with forged Con-rod and Crank
                2002 C200 KOMPRESSOR
                1995 318i - M42B21 on the making
                1986 325e - Just another Project
                1989 M6 - SOLD in DXB
                • Simon S
                  • Oct 2004
                  • 3758
                  BP's BMW E30 318is Site
                  stellar resource.
                  -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                  • strad
                    • Jan 2007
                    • 241
                    Mine has 195k with no chain noise (just installed a new M44 tensioner). Had the lower pan off and all the bolts were tight too. Pulls strong. I'm thinking about selling my 2000 mustang, which though very well maintained is turning into a POS at 90k miles, and keeping the little M42. The wife likes the M42 because it's red! :)
                    The current fleet:
                    1992 325ic: 148k-171k miles
                    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                    • golde30
                      • 11464
                      you guys should see the 226K miles m42 that was in the 318is i bought. that thing looked like some1 put a grenade on top of the #1 piston. i believe it dropped a valve, and the PO decided to keep driving it as long as he could till it just stopped moving.when i dropped the oil pan, there were HUGE chunks of metal in there. ever since then i have been scared of driving my m42 hard, i baby the shit out of it. my m20 on the other hand, gets driven quite hard...
                      IG: @Baye30
                      • NOMAD
                        • Feb 2007
                        • 1502
                        Do NOT let them overheat. From what I read it's a really strong engine but dayum if mine didn't just take a dump. The little plastic water pipe under the intake manifold cracked, dumped coolant out and the engine overheated. I replace a bunch of hoses etc but the damage was done. I'll find out tomorrow if it's a warped headgasket or a cracked head.
                        There are a few nitpicky issues with these engines, the later M44 has all the kinks worked out from what I see.
                        No more issues than other cars like it but issues nonetheless.
                        Get the best condition engine you can find, then still plan on replacing critical components and DO NOT WAIT. Once you take care of hoses, vacuum lines, water pump, t-stat, timing chain, chain tensioner, fluids, gaskets etc you should be really happy.
                        '74 2002 - Build blog at
                        nomads2002.blogspot.com
