m42 tranny mate to and m20???
  • bimmer_adam69
    • Mar 2006
    • 223
    yes will it????? anyone know????
    buddy's doing a 5 speed swap tmorrow
    M stands for Money:hitler:
  • bimmer_adam69
    • Mar 2006
    • 223
    bump...please anyone
    • ZiMMie
      • Jun 2004
      • 968
      yes it will.
      but u will need the m42 Driveshaft.
      www.stancefactory.com
      • thebmwM
        • 174
        I have an m42 drive shaft FS!!!
        • asubimmer
          • 6482
          as do I ;)
          • bimmer_adam69
            • Mar 2006
            • 223
            sweet thanks guys! and thanks for the ds offer but im getting everything i need for the swap for 200 bucks so im gravy
            • iNetForce
              • Mar 2007
              • 82
              I have a 318is and a M20 engine. Based on what you guys wrote I can go ahead and swap the M20 in and use my current drive train? Am I right?
              • strad
                • Jan 2007
                • 241
                And related to ^^^ an M50 will mount to my M42 sedan's trans as well, right?
                Not suggesting it's a good idea btw. Or that I'm going to do it asap either. Purely academic.
                The current fleet:
                1992 325ic: 148k-171k miles
                1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                • asubimmer
                  • 6482
                  yes the getrag 240 from the late model 318's fit right up to the m50
                  • amdspitfire
                    • Mar 2006
                    • 254
                    are they strong/good enough for a s50?
                    • Rocla
                      • 922
                      Threadjack.
                      How about using m50 transmission with m42 engine to achieve close ratio?
                      Will m50 transmission line correct with m42 engine or will it be angled? Will any existing driveshaft work or do I have to manufacture special shaft from eta/td/m3 pieces?
                      Current:
                      BMW 320i 2d 2.0 m20 -88
                      BMW 325i Cabriolet 2.5 m50 -88
                      BMW 316i touring 1.6 m40 -90
                      BMW 320i 4d 2,2 m54 -01
                      • asubimmer
                        • 6482
                        the e36 tranny would fit, not sure about what driveshaft it would need though. The block design of the m42 and m50 are pretty much the same so the angles are = also.
                        And yes the 318 tranny can handle the power of an m50, they are rated at 240lbs of tq. Although I did just loose 1-4 on my tranny a few days ago but that was due to it having close to 300k on it. It had trouble getting into 1st when it was cold before it went on the m50. I knew it was on its last leg but I decided to get my $ out of it.
