Help with timing parts
  • Jak
    • 62
    I ordered a few parts that weren't completely necessary but here is the complete list of the parts I used. I did get my overheating issue resolved. It seems I had a large air pocket stuck in the heater core. I ended up bleeding the system for over 30 minutes to get it out. Now the needle sits right between the 1/4 and 1/2 mark like its supposed to.
    What site is B Purcells?
    Sorry the formatting is messed up. These were taken from various emails.
    11 31 1 721 887 │CAM SPROCKET │ 2.00 │ 36.00
    11 21 1 247 338 │CRANK SPROCKET │ 1.00 │ 45.67
    11 31 1 727 569 │DEFLECTION WHEEL │ 1.00 │ 69.00
    11 31 1 247 470 │GUIDE RAIL │ 1.00 │ 47.00
    11 31 1 727 342 │TENSIONER RAIL │ 1.00 │ 88.65
    11 31 1 721 419 │RAIL GUIDE │ 1.00 │ 38.00
    11 14 1 721 802 │TIMING CHAIN GASKET │ 1.00 │ 9.00
    11 14 1 721 919 │FRONT COVER GASKET │ 1.00 │ 4.50
    11 14 1 247 837 │T-COVER GASKET │ 1.00 │ 3.80
    12 31 1 717 898 │ADJ. BAR │ 1.00 │ 5.50
    32 42 1 714 641 │ADJUSTING BAR │ 1.00 │ 7.15
    Pully bolt (6) 07119900268
    Crank stretch bolt (1) : 11211721100 - $0.40
    Water pump bolt (3) : 07119915190 - $0.30 each
    Water pump bolt (1) : 07119901036 - $2.00
    Water pump bolt washer (1) : 07119900052 - $0.14
    Water pump – 11 51 1 734 595 - $55.00
    Thermostat housing gasket (1) : 11531721172 - $5.00
    Thermostat housing bolt (4) : 07119901943 - $0.45 each
    Thermostat housing (1) : 11531721966 - $31.00
    Thermostat – 11 53 1 721 002 - $12.00
    Upper and lower radiator hoses - $17.00 (lower) and $12.00 (upper)
    Lower oil pan seal – $10.00
    Power steering pump v-belt (1) : 10x800 - $5.50
    Alternator/water pump v-belt (1) : 10x1025 - $5.50
    Timing Chain 11-31-1-247-160-M48 , $56.75
    Chain Tensioner Piston 11-31-1-743-187-M40 $42.25
    I think thats everything...
    • j3ff
      • Feb 2006
      • 41
      B Purcell's site is: http://www.esatclear.ie/~bpurcell/
      Best 318is specific resource I've found so far, thanks to this board.
      And thanks a lot for your parts list.
      • j3ff
        • Feb 2006
        • 41
        One other question Jak..
        What are:
        Looking them up on pelican doesn't really help..
        • ak96ss
          • Nov 2005
          • 461
          www.realoem.com - they are the mounts for the alternator and power steering pump.
          John in MD - 1991 318is
          190k miles and still rolling!
          • Jak
            • 62
            Ak96ss knows his part numbers. I had to replace those because the teeth were all chewed up before I even loosened them.
            Oh and thanks for that link. I did have it bookmarked already, I just didn't recognize the name.
            • bmwpower
              • 1556
              Did you just buy these?? Did you use any sort of discount code for BMA?
              89 325is track project / 05 x5 / 99 M3
              E30 stuff for sale | Parts I'm looking for
              • Jak
                • 62
                Many of the parts were special order. I told Yves that I was referred by Jordan and R3vlimited but no discount code. He did price match some of the stuff though, saved me about $60.
                Also I ordered some of the parts from pelican before I knew about BMA.
                • bmwpower
                  • 1556
                  Where'd you get that deflection wheel price for the price match? All the ones I've seen are $$.
                  • 1991 318is
                    • Dec 2005
                    • 786
                    Originally posted by Joe318is
                    i see it now, i forgot what those are supposed to look like but after a quick google search i see how bad those are.
                    Whats the story on this engine?
                    They last with regular oil changes and aren't abused.. Like a lot of older cars, maintenance is neglected after they go through a few owners.
                    • Jak
                      • 62
                      Absolutely, which is surprising since I have an inch thick folder of all the maintenance receipts. I guess the car could have been run pretty hard though.
                      As for the source of my low price deflection gear, I don't remember for sure but here is an example. http://www.autopartswarehouse.com/se...294967020+6348.
                      Yves looked it up and after a minute or so told me he'd have no problem matching it. I spent a few evenings doing price research before I called him and I was just thinking I'd order from multiple places with the best prices. I didn't plan on him price matching.
                      I actually have my old one and it looks like new. I wouldn't have replaced it had I looked at it first. I may put it on Ebay and see if anyone wants to save $$.
                      • JiXer
                        • 620
                        A lot of what I read on his site is inaccurate.
                        Most of what was correct is common knowledge, but most of it seems to come from reading too many message boards and manufacturer's hype.
                        J.
                        Results-driven technical leader with 25+ years across racing operations, automotive technology, and instructional design. Founded and scaled Big Fish Motorsports from a performance shop into a nationally recognized racing brand.
                        J. Farina
                        Yeah, thats me kicking up all that dirt!
