I ordered a few parts that weren't completely necessary but here is the complete list of the parts I used. I did get my overheating issue resolved. It seems I had a large air pocket stuck in the heater core. I ended up bleeding the system for over 30 minutes to get it out. Now the needle sits right between the 1/4 and 1/2 mark like its supposed to.
What site is B Purcells?
Sorry the formatting is messed up. These were taken from various emails.
11 31 1 721 887 │CAM SPROCKET │ 2.00 │ 36.00
11 21 1 247 338 │CRANK SPROCKET │ 1.00 │ 45.67
11 31 1 727 569 │DEFLECTION WHEEL │ 1.00 │ 69.00
11 31 1 247 470 │GUIDE RAIL │ 1.00 │ 47.00
11 31 1 727 342 │TENSIONER RAIL │ 1.00 │ 88.65
11 31 1 721 419 │RAIL GUIDE │ 1.00 │ 38.00
11 14 1 721 802 │TIMING CHAIN GASKET │ 1.00 │ 9.00
11 14 1 721 919 │FRONT COVER GASKET │ 1.00 │ 4.50
11 14 1 247 837 │T-COVER GASKET │ 1.00 │ 3.80
12 31 1 717 898 │ADJ. BAR │ 1.00 │ 5.50
32 42 1 714 641 │ADJUSTING BAR │ 1.00 │ 7.15
Pully bolt (6) 07119900268
Crank stretch bolt (1) : 11211721100 - $0.40
Water pump bolt (3) : 07119915190 - $0.30 each
Water pump bolt (1) : 07119901036 - $2.00
Water pump bolt washer (1) : 07119900052 - $0.14
Water pump – 11 51 1 734 595 - $55.00
Thermostat housing gasket (1) : 11531721172 - $5.00
Thermostat housing bolt (4) : 07119901943 - $0.45 each
Thermostat housing (1) : 11531721966 - $31.00
Thermostat – 11 53 1 721 002 - $12.00
Upper and lower radiator hoses - $17.00 (lower) and $12.00 (upper)
Lower oil pan seal – $10.00
Power steering pump v-belt (1) : 10x800 - $5.50
Alternator/water pump v-belt (1) : 10x1025 - $5.50
Timing Chain 11-31-1-247-160-M48 , $56.75
Chain Tensioner Piston 11-31-1-743-187-M40 $42.25
I think thats everything...
