M42 won't start
  • kencopperwheat
    King of Kegstands
    • 14396
    M42 won't start
    So after work I went to start up the car and it just kept cranking.
    -Fuel pump IS working (should as it's fairly new from the dealer).
    -All fuses are intact.
    -Coils have <10k miles on them.
    Any ideas? I'm hoping to replace the Crankshaft Postion Sensor this evening.
    Originally posted by Gruelius
  • FL318is
    • Sep 2006
    • 1396
    ICV or TPS or try M42club.com
    • kencopperwheat
      King of Kegstands
      • 14396
      ICV is fairly new from the dealer
      I'll check the TPS too
      • Jordan
        • 12913
        OHM out the CPS.
        ICV isn't going to prevent a start, nor will the TPS.
        https://mtechniqueabs.com/
        • restoration
          • Oct 2007
          • 67
          my old 318i left me stranded and i found out that it was the ECU(brain) it was not programing engine to inject fuel, and those coil should not be a problem, check for spark and the usual trouleshooting
          • FredK
            • 14761
            Was it working fine before, or are you trying to start a car that you've never seen running?
            • restoration
              • Oct 2007
              • 67
              At the breakfast his car was running quite well
              • Joe318is
                • Sep 2005
                • 6451
                Does it even try to start [sputter, hickup]?
                Originally posted by vlad
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  I'll try and swap ECUs too.
                  Yes, the car ran perfectly that morning.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    No, just cranks and cranks.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Originally posted by Jordan
                      OHM out the CPS.
                      It's going to be dark and cold. I'm just going to swap it.
                      Yeah, i didn't figure either of them would prevent it from actually starting up.
                      What about the cold start valve? Do M42s have them? Or would a faulty one just prevent it from starting up right away?
                      • Van Westervelt
                        • 9365
                        getting fuel to the engine? recently put a chip in it?
                        • Joe318is
                          • Sep 2005
                          • 6451
                          One thing ive heard people complain about had been the crank ref sensor. ive never had an issue with it before [my m42 hasnt acted up in 50k and 4.5 years]
                          Its on the drivers side [i think] one lead going in, looks like a little black barrel. It could be gunked up, loose, or broken.
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            The fuel pump is working, I can only assume that it's getting fuel.
                            Haven't touched the ECU at all.
                            • Joe318is
                              • Sep 2005
                              • 6451
                              Fuel pump working doesnt mean its getting fuel. if the injectors are not firing, which would be a fuel management issue [sensors, ecu, etc.] then there is no fuel being delivered into the cylinder.
