M42 fail emissions
  • E30nate
    • Oct 2007
    • 1050
    M42 fail emissions
    i tested my cars emissions at school the other day, kinda like a pre test, and it had high HC's and high NOx. i noticed there is quite a bit of oil on the inside of the intake boot. my teacher told me that it is probably the PCV Valve is stuck open. i was looking for the pcv system on all data, and found nothing.
    my question is; is there a pcv valve, or is there some other sort of crank case ventilation?
  • Joe318is
    • Sep 2005
    • 6451
    no, crank case vent goes back into the intake
    Originally posted by vlad
    • E30nate
      • Oct 2007
      • 1050
      is there anything to keep the oil from gitting in the intake? i ordered a new intake boot and hoses because the oil made the old ones crack. is there like a breather or something with a filter on it that i can check?
      • Joe318is
        • Sep 2005
        • 6451
        Make a simple breather, IE little cone filter on the end of the crank case vent. then plug off the intake boot nipple.
        I dont think thats your problem.
        • E30nate
          • Oct 2007
          • 1050
          my teacher was also saying it could be a possible vacuum leake. also when i rev it pretty high, like 5500, after i let off to shift it hisses like a BOV. are there and hidden vacuum lines that could be broken or damaged?
          • Joe318is
            • Sep 2005
            • 6451
            HAHAHA, TONS! There are all sorts of vaccume lines under the intake manifold, its a known problem with M42's.
            Go here: http://www.realoem.com/bmw/
            Find yer car and look at the exploaded views.
            • E30nate
              • Oct 2007
              • 1050
              i went to realoem.com and couldnt find the exploded views. is there a link you can send me to find it. i will keep looking for an exploded view somewhere else though.
              • E30nate
                • Oct 2007
                • 1050
                i found a diagram of the vacuum lines on the net. i also went to my brothers shop and ran the smoke machine through the intake. that made it a lot easier to find the leak. i need to replace the two intake manifold gaskets.
                • buhnahnuh
                  • Nov 2007
                  • 69
                  I just deleted the cooling plate and got rid of a bunch of hoses. I replaced both intake gaskets and they were only 7.50 each, I replaced all vacumme lines maximum 30 dollars. All my lines were cracked and broken, taped a ziptied. That could be the problem... when i put the new injctors and hoses in it ran fine
                  let us know if problem persists might be able to provide help
                  • tjts1
                    • May 2007
                    • 1851
                    This is whats hiding under your intake.
                    • E30nate
                      • Oct 2007
                      • 1050
                      i have the lower intake gasket, the upper is on the way. ill change them this weekend. i will have my brother order me all the vacuum lines and other hoses as well. his boss doesnt mark up prices for him or his family, so i get parts at cost. helps out a lot. i will keep you guys posted as to my progress.
