I think I may have a problem?
  • The_RavEn30
    • Apr 2006
    • 121
    This morning we discovered that there was some coolant on the floor of the drivers side.
    So I warmed it up and took it for a test drive and nothing spilled out as I was driving it. So about 10 minutes later, I came back home, and opened the hood. I checked the oil cap and noticed there was very little yellow substance on it. But to me it wasn't enough to indicate that I had a cracked head, unless it recently cracked?
    So I pulled out the oil stick and let some oil drop on the engine and I noticed there were bubbles in the oil, but the oil seemed to be the regular color.
    Is that normal or do I have a serious problem ahead of me?
    Thanks in advanced.:)
    Andrew
    91 325iA sedan - lagunengrün-metallic
  • Joe318is
    • Sep 2005
    • 6451
    Coolant on the floor is the heatercore and dosent have anything [other than sharing coolant] to do with the motor.
    Originally posted by vlad
    • The_RavEn30
      • Apr 2006
      • 121
      But isn't normally the heater core on the passenger side?
      Andrew
      • Joe318is
        • Sep 2005
        • 6451
        Nope, drivers side [as long as its left hand drive]. The heatercore and valve may have bad o-rings, or the plastic may be cracked on the heatercore, it gets brittle.
        • The_RavEn30
          • Apr 2006
          • 121
          Gotcha. Thanks.
          But what about the bubbles in the oil?
          Andrew
          • Joe318is
            • Sep 2005
            • 6451
            Thats just normal
            The 'whitish' crap on the cap is usually from water getting into the oil, nothing to worry about.
            • Justinian
              • Oct 2007
              • 16
              Especially if your going on lots of short trips. I've seen M42's with suspicious looking oil if there is a combination of cold weather with lots of short trips.
              If you haven't taken the car for a decent drive try it and I bet any condensation you have will clear up.
              Have to love the E24... and the E30 of course.
