Oil drain bolt snapped.
  • Vicarious
    • 223
    I was doing an oil change, and when tightening the bolt back in after it all drained out, it snapped, most of the thread is still in. Do i need a whole new oil pan now?
    Has this happened to anyone else?
  • Skoobeesnak
    • Jun 2006
    • 132
    Go to your local auto parts store and ask for an easy out. That will save your bacon. And remember not to tighten the next one so much.
    • Funkmasta
      • May 2004
      • 7185
      Get a new lower pan, it is about $75 (used) and takes 3 hours TOPS.
      Before you can easy-out, you must first drill, which is bad ;)
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • erik325i
        • Jan 2005
        • 3567
        Just drill and easy-out it. If you fuck up doing that, then replace your lower oilpan.
        -Erik
        • Funkmasta
          • May 2004
          • 7185
          how did the bolt break before the aluminum stripped?
          I would remove the pan to clean out the shavings...
          That Guy.
          • erik325i
            • Jan 2005
            • 3567
            Yeah, that's a good question. The alluminum is very soft and the threads will strip out easily before a steel bolt will snap.
            -Erik
            • mattdk318i
              • Jun 2006
              • 3953
              go to bavauto and i believe they are like 99$. Well worth it IMHO. Make sure you get a gasket.
              Once you get the old one off it will be easier to deal with and you can use it as a spare.
