Thanks to MarkD and to Doug (haledj)
  • Nivola
    • Mar 2008
    • 16
    Well, over the weekend, there were quite a few projects for das Viereck (the Rectangle):
    Installed the E.A.T. chip (91 Oct.) from MarkD.
    Installed the COP kit from Doug (using BavAuto higher capacity discharge plasma coils from my E36/8 M coupe).
    Installed a MoMo Monte Carlo 355mm wheel.
    Painted my washer fluid resevoir black (keeping with my red/black theme).
    My engine bay on the day I bought her back on February 10, 2008:
    My engine bay today, April 21, 2008:
    The MoMo is great (I can keep my hands at 9 and 3 o'clock through many more turns) and it will be even better when I do a E36 3.2 ratio rack this week, in addition to some lighting upgrades, too. :)
    But, most importantly, the E.A.T. chip and COP kit completely has changed the character of the car. She is a little rev beast now. :D
    There was some re-dialing in of the idle and I did need to re-wire the connections to the coil-over-plugs to remedy a cold-start, bogging issue, but now she just sings!
    So, thank you very much Mark and Doug! Your excellent work and customer service is greatly appreciated. ;)
    Ciao,
    Nivola
  • bats
    • Jan 2008
    • 128
    The COP has performance gains? I thought it was a good idea since it removes the usage of plug wires.
    • BBY1104
      Looks terrific!!
      • olde30is
        • Apr 2008
        • 9
        looks great! Can you tell me where I can get one of those strut braces?
        • Joe318is
          • Sep 2005
          • 6451
          Not really, just less to go bad and less expense to maintain.
          Originally posted by vlad
          • Nivola
            • Mar 2008
            • 16
            Definitely. The main gains I experienced were from the chip. My plug lines were original (and not good), so the gains of good spark were also experienced -- just in my case or for those with bad OEM plug lines.
            • MarkD
              • Sep 2004
              • 488
              Ciao,
              Nivola
              Hi Nivola, thanks for the mention. I only saw your post today.
              Mark
              URL: www.dsylva-tech.ca
              • Nivola
                • Mar 2008
                • 16
                Mark
                You are quite welcome, Mark! :grin:
                • BUDNUNTA
                  • Apr 2005
                  • 996
                  Did you shorten your connectors to the new coils?
                  I just got my kit and think I can just hide the extra wire behind the harness cover.
                  Im questioning taking those connectors apart. There so old and brittle.
                  Hunter
                  We're out there in here.
                  • Nivola
                    • Mar 2008
                    • 16
                    Hunter
                    Nope, did not shorten them.
