i got 1 2 1 5 on the stomp test- something to do with afm /maf...no vacuum leaks and i know my throttle cable isn't the greatest, but it shouldn't make it cout out....hope this helps
engine cuts out at 4500
Coincidentally, I'm getting the same thing. I've read the 1215 code indicates that the AFM wiring harness is at fault. A spare AFM and ECU didn't help mine either. The vacuum lines are good too. Is there a way to troubleshoot the wiring? -
you're in chambersburg? Bring it by my place sometime and I'll take a look at it.Old and improved:
