MM and TM Q'ion
  • BBY1104
    • Oct 2026
    MM and TM Q'ion
    What is the Best way to change motor mounts and transmission mounts?
    Can i lift the engine from the metal loop at the front of the intake mani, just looking for ways you guys do it. Any response is appreciated!!
  • txleadfoot
    • Apr 2006
    • 208
    Yes, you can use the loop at the front to lift the engine. Might be easier to simply jack with a block of wood underneath the oil pan though. Keep an eye on the engine near the firewall. I'd also remove the fan.
    • BBY1104
      Taking the fan off will help clear rad. and shroud correct?
      • Joe318is
        • Sep 2005
        • 6451
        yeah. also watch the PS lines.
        Originally posted by vlad
        • BBY1104
          Ok, I am going to use a cherry picker and jack from underneath
          • smonkbmw
            Professor
            • Jun 2006
            • 4549
            how weird! isnt that what me and curt both said to do from the beginning? odd...
            • BBY1104
              /\ I was originally only going to jack it, I was not sure If a hook would fit in that metal loop
              • smonkbmw
                Professor
                • Jun 2006
                • 4549
                a section of chain and a snap ring (i think thats what they are called) work wonders.
                • tjts1
                  • May 2007
                  • 1851
                  Just use a hydraulic jack and a block of wood under the oil pan. easy as pie. Don't forget to have the hood open. Ask me how i know.
                  • BBY1104
                    ok, friday is the day. Everything should be okay. A couple of local friends assured me that it would be easy and it is simple
