Overheating in traffic
  • 3two8eye
    • 84
    I have a 1991 318is and I am experiencing an overheating problem.
    Symptoms:
    Car operates at normal temp while moving.
    When stopped in traffic the gauge creeps up (to just shy of the red, although if I sit long enough I suppose it would) until I start moving again.
    Then the temp drops back to normal quickly.
    This sounds like a fan issue of some sort to me. What is the most common place to start? Fan clutch? Or is there other checks I should do first.
    I tried searching both here and e30tech and couldn't find this problem.
    Thanks, Tyler
  • lifestyle101
    • Jun 2008
    • 552
    replace the radiator
    • txleadfoot
      • Apr 2006
      • 208
      roll up some newspaper and put it in the fan while running. if it stops, replace the fan clutch. if it shreds the paper, start looking elsewhere.
      • n2motorsports
        • Jun 2007
        • 173
        swapping out my thermostat fixed the same problem, but could be other things too, like the bypass off the heater core. does your heater blow hot air?
        • 3two8eye
          • 84
          I'll check these things out. Thanks for the suggestions
