vr6 injectors???
    vr6 injectors???
    can someone give a straight answer on if i can use vr6 injectors on my m42 and will it giv me any gain
    What mods have you done so far? What makes you want bigger injectors? (assuming vr6injectors are bigger)
      I had ford injectors, it just uses more gas, unless you got more air bigger injectors arnt needed....IMO
        I know this is an 'old post', from June, but...
        Being new to the BMW DME stuff, but not new to performance builds, I'd "assume" you can't just throw bigger injectors at the car and the DME be okay with them.. ??
        If so, man, I've been missing out! lol
        I think the VR6 injectors are around 395cc/min @ 3 bar, and high Impedence..
        M42 injectors are around 214cc/min at 43.7psi (3 bar)
        that's a helluva lot more fuel..
        ~Rogan
        '85 325e w/M42 swap
        '02 WRX 2.5L Hybrid w/GT32 @ 20psi - 400+awhp :: SOLD
        http://www.autismspeaks.org ||| http://www.essentialpieces.org
        Strategic Alpine Command
        Diving Board Division
          M42 injectors are 192cc and the engine runs extremely lean at WOT past 3k. I switched to 230cc injectors.
            thanks. I pulled the numbers from Google, but no worries.. :up:
            ~Rogan
            '85 325e w/M42 swap
