Ok, so here's the dealio.. I picked up an E30 on the cheap.. motor was busted, interior gone, etc.. Friend had an M42 laying around from his swap.
so we got it in, and I'm working on the harness conversion from the round 'late E30' plug to the 'early square' one..
Square plug is 19-pin plug with 8 blanks.
Round plug is 20 pin with a few blanks; don't remember exactly how many off-hand.
Well, I wired the pigtail to the square plug, and matched pin for pin, in relation to their function (i.e. '85 pin16 to '91 pin5 = oil pressure) and so on..
I have about 7 wires left over from the round plug, that have no home; most are sensors I believe. All other wires that have been mated were color-for-color, gauge-for-gauge..
Tracing these remaining wires back to inside the round plug, they go to pins that are considered 'empty', per the wiring schematics from TIS.
Ex. pins 14, 15 = blank per schematics, yet both have wires... :roll:
Q#1: does anyone have ACCURATE wiring for these plugs?
Q#2: replacing the 325e cluster with an iS cluster... plugs appear to bbe identical... "should" everything in the cluster work, with PnP operation? Or do I need to make/add wiring changes?
