First time oil change on an M42
  • ash00
    • Nov 2007
    • 22
    Hey Gang,
    I'm going to do the first oil change on the '91 318 that I just bought. What type of oil do you guys recommend?
    [SIGPIC]*******
    Aashish
    '69 BMW 2002
    '75 Innocenti Mini
    '87 325is w/S52
    '04 BMW 330i ZHP
    '04 Tacoma--parts hauler!
  • tjts1
    • May 2007
    • 1851
    Extra virgin olive oil.
    • EN318isPDX
      • Oct 2007
      • 4373
      lol....
      I use regular 10-40 oil but that's because mine leaks out of the front of the motor.. I would recommend Synthetic if you dont leak oil, i recommend a 40 weight.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Don't they require castrol 10/30 or am I on crack? I thought thats what the cap says.
        • EN318isPDX
          • Oct 2007
          • 4373
          Hmm my cap doesnt say anything on it.. maybe its time to go synthetic this oil change
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            It may be the m44 I'm thinking of.
            • submwar
              • 216
              you're a JiffyNoob
              • Fred-k
                • 4
                I work at a Lube shop.
                what temperature and Heght are you at?
                I would recomend 10w40 or a 15w40 full synthetic
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Thanks Fred-K
                  • E30 Motorsports
                    • 58
                    Whatever you decide, I work for E30 Motorsports, and will do my best to get you a deal. We carry the full line of Amsoil products. Id recommend the 5w-40 European Blend. Let me know.
                    -Andre
                    E30 Motorsports
                    http://www.e30motorsports.com
                    E30 Racing, Parts, and Accessories
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      I prefer 10w40. 10w30 is too light for the M42; the lifters will make a lot of noise. 5w40 would work too, but it can be tough to find.
                      I run full synthetic in my motor, with few leaks and no burning. If your motor leaks badly, though, I'd stick with dino oil.
                      Project M42 Turbo
                      • adam12hicks
                        • Jun 2008
                        • 42
                        Yeah I use Mobil 1 10w40 in mine. It's not cheap, but it's a LOT cheaper than the Castrol Racing 10w60 in my M Roadster ($11 a quart x 8 :( )
                        Adam
                        06 Z4 ///M Roadster (slightly quicker than the e30)
                        05 X5 (slightly roomier than the e30)
                        91 318is Alpine White (IS the e30)
                        • kansas-ix
                          • Jan 2004
                          • 1600
                          i use 10-40 mobil 1 and mahle filters. 5k intervals.
                          Originally posted by EN318isPDX
                          lol....
                          sounds like front main seal bearing $300 done, or crazy cheap if you have the tools.
                          E30 325ix 62k
                          • Magnetraction
                            • May 2008
                            • 32
                            I use 10-40 full synth and have some front engine leak/seeping. not very much tho, and no problems yet
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              I'm pretty sure its leaking out of the timing case and most of its leaking out the lower oil pain due to someone stripping out 75% of the holes. I saw someone change the oil pan into studs, that might be the answer to my problem.
