M44 Transplantation
  • Memphys™
    • 33
    M44 Transplantation
    Hey guys, i'm planing to install an M44 engine from E36 to my E30 Touring, so my question is is there any isues while doing this, i got the hole pack - the engine, trany, wires, the ECU, is there any difference with mounting the engine from E36 to E30 and is there any parts i need to have to comlpete it?
    Thanks
  • hesgone2fast
    • Jan 2006
    • 16
    You need to use the following:
    E30 oil pan
    E30 oil dipstick
    E30 intake
    E30 complete engine harness including crank and cam sensor(exhaust cam)
    E30 belt system, You could use the serpentine system from the M44, but the dipstick needs a little bending with a looooot of care, so if you don´t want to mess, use the E30 belts and pulleys.
    E30 crank pulley so the E30 ECU can read the Crank position. In the M44 is inside the block.
    E30 ignition coils and plug wires
    This is all I can think of right now, I might be missing something though...
    I hope this helps!!
    • Memphys™
      • 33
      E30 oil pan
      E30 oil dipstick
      E30 intake
      I hope this helps!!
      Thanks alot man, can u tell me more about oil dipstick cause i cant translate it
      • Sam Cogley
        • Jun 2008
        • 521
        The thing you use to measure the oil level.
