Diff choices in M42 cabrio
  • txleadfoot
    • Apr 2006
    • 208
    My '92 318ic has a 4.27 open diff with a stock, chipped M42. Has anyone swapped to a lower ratio rear-end without causing weird shifting issues in regards to available torque? My last car was a '91 318is with 4.10 diff and damn, this cabrio accelerates like a tank in comparison (300# difference). I'm guessing if I go lower ratio, that's gonna kill acceleration in favor of less revs on the highway. What's available out there PnP?
  • tjts1
    • May 2007
    • 1851
    Anything is available. It depends what you want out of the car. I use a 3.64 in my 318i sedan but it is lighter than the convertible. I think a 3.91 would be a good choice in your case.
    • BMWLA
      • Jul 2008
      • 407
      The ic is a lot hevier than the is are you sure that it has a 4.27 tho?
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        All late-models 318iC's had a 4.27, yes.
        I know a guy running an OBD1 S52 through a ZF and the stock 4.27 in his 318iC. 1st and 2nd gear are completely useless, and he tops out at like 85mph...
        But it will snap your fucking neck off if you have the guts to WOT it
        • kencopperwheat
          King of Kegstands
          • 14396
          I'd try and find a 4.10 LSD. You can run a small case with the M42 as well.
          Originally posted by Gruelius
          • Joe318is
            • Sep 2005
            • 6451
            3.73 in a 318is is very nice. im sure you could get away with the same diff in a cabiro despite the extra weight.
            Originally posted by vlad
            • txleadfoot
              • Apr 2006
              • 208
              Hmmm....small case?
              I will look into that. Is that a small case and what model was it available from at the factory?
              • tjts1
                • May 2007
                • 1851
                All 4 cylinder E30s sold in the US had a small case diff. These have 6 bolts on the diff cover. The small case ratios available are 4.27, 4.11, 3.91 and 3.64. There was a 4.45 and 3.45 small case diff in the E36 318ti which is also compatible. The 8 bolt medium case diff is also a direct swap into your car. That one is available in about 10 different ratios which I'm not going to list. I'm on the hunt for medium case 3.73 LSD at this point.
                • Joe318is
                  • Sep 2005
                  • 6451
                  3.73's are VERY common. Most 325i/s had them.
                  • naplesE30
                    • Nov 2007
                    • 1841
                    I have 3.73 lsd in my 318is and love it.... Much better on the highway than my open 4.10
                    • txleadfoot
                      • Apr 2006
                      • 208
                      how does it perform from a stop? curious about city driving.
                      • Joe318is
                        • Sep 2005
                        • 6451
                        better than the 4.10ls
                        i autox this thing, its WAY better for the car.
                        • tjts1
                          • May 2007
                          • 1851
                          These cars should have had a 3.73 from the factory. There is nothing to gain from a 4.10 or 4.27 in the real world.
                          • ///M42 sport
                            • 3952
                            What diff for efficiency?
                            • marksv4
                              • Mar 2006
                              • 174
                              my diff in my 91 cab has a 2.93 open......
                              91 E30 318is DS/Anthrazit S14 & 5 bolt
                              99 E36 M3 Cosmos/black leather
                              06 E90 330i Black Sapphire/black vinyl stuff
                              WTB: Black 71-76 2002
                              www.bcbimmers.com
