Low idle, stomp test throws 1222
    Lambda code.
    I unplugged the ECU and accidentally plugged my Air/Fuel gauge into the AFM pin instead of the O2 pin.
    Then when I plug the Ecu back in and start the car it idles too low and the stomp test reveals a 1222, could this have something to do with the ECU being unplugged?
    Checked all the vacuum lines, everything seems to be in order.
      did you reset the dme?
      84 318I Delphin RIP
      87 325IS delphin 24v Sold
      89 325 Alpineweiss
        What do you mean?
          disconect the batt for like 10 15 seconds and see if it goes away... scince you accidentally plugged the Air/Fuel gauge into the AFM pin instead of the O2 pin
          84 318I Delphin RIP
          89 325 Alpineweiss
            Well I unplugged the ECU completely so it should lose power and turn off.
            I'll leave the battery disconnected over night and see what it does.
              O
              84 318I Delphin RIP
              89 325 Alpineweiss
                Did that code go away? When disconecting the edu you should always disconect the batt
                84 318I Delphin RIP
                89 325 Alpineweiss
                  Yeah it did, everything is back to normal.
                  Thanks a bunch!
                    glad it's ok.
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                      So disconnecting the batt fixed it?
                      -Pierre
                      1987 535is
                      1988 325is
                        Yep, the ECU reset and everything was fine.
                          Danny, you're running a narrowband o2 gauge?.. That about as useful as a condom for a dick amputee.
                          1985 325e 2.8 Turbo VEMS
                            1222 is BS. it covers too much
                            1222 = 'Uh yeah, somethings wrong with the left side of the engine'
                            Originally posted by vlad
                              This was before the turbo actually.
