low compression no starting issues.
  • rallyegolf
    • May 2008
    • 96
    Let me fill you in on my issue.
    spark good-
    fuel good-
    sensors good-
    relays good-
    compression bad-
    dry test.
    1=120
    2=150
    3=75
    4=70
    after a little oil in cylinders
    1=120
    2=180
    3=120
    4=120
    I tried the 2nd cylinder again,and hit 150 after the first 180. "harbor freight compression tester"
    So I think the compression was so low because the motor was cold, but it is at least every cylinder sucks the same amount. "kind of"
    I think I need to remove the intake manifold next and test the resistance on the injectors and test the fuel pressure regulator. Can I test the regulator, or do I just replace it?
    How can I tell if my ECU works correctly? Maybe that is what I need???
    What would you guys check?
