Coolant temp seems to dip slightly when using heater?
  • BraveUlysses
    • Jun 2007
    • 3781
    I recently tore apart a good portion of my 318iS to replace most of the gaskets and remove the "mess under the intake manifold."
    In doing so, some coolant drained out of the block but I topped it all off after putting everything back together...car drives fine, heats up like it should but it seems that when I turn on the heater (it still blows hot) the temp gauge moves a slight bit away from the middle mark...which I don't recall it doing before (but I only drove it 5 days before tearing it all apart to fix everything, so I'm not sure how it should behave).
    Is this normal? Or maybe due to the fact I didn't bleed the cooling system?
  • Jordan325iC
    • Aug 2005
    • 1697
    It would make sense that turning on the heater would cause a very slight shift in coolant temperature, since that it just one more outlet for heat to escape from the coolant. I don't think you have a problem.
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
    • Doughnut
      • Oct 2007
      • 869
      +1.
      I have used my heater to cool the temperature of the engine in stop go traffic a couple of times, pointing at the windscreen with fan on full of course.
      ///Monstrosity. (OO≡≡[][]≡≡OO)
      Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
