E30 / E36 M42 Clutch Interchangable?
  • PrinceE30
    • 282
    Simple as that, can you use a clutch from an E36 318i in an E30 318i? Or vise versa?
    Thanks!
    Randall Prince
    http://www.rp1.us/ Used Cars
  • FredK
    • 14752
    It looks to be interchangeable. Both have a 215mm clutch disc with kit PN 21211223570.
    • eugeman
      • Sep 2007
      • 306
      yes.
      • isamemon
        • Jan 2009
        • 257
        but you can also, switch to a m20 flywheel, use the conversion parts and drop 10 lbs off your flywheel, all for the only extra cost of a used flywheel and stater. note it does use a different pressure plate and disc, all standard bmw stuff, but off different models
