What is this sound and why does it happen...
  • 16v of E30
    • 157
    So I decided to swap over my summer rims today in the nice sunny pemberton weather and was faced with a few issues. Currently I am running 14" studded snows and i was looking to put my 17" Enkei's on.
    There was no known noises or anything wrong with the drivetrain beforehand, but after swapping on the wheels and going for a test roll I got a clicking noise in the back end consistant with the speed the wheel was rotating.
    I jacked up the back end and spun the wheels in 1st gear and the clicking was still there...and no signs of rubbing. I then put the winters back on and spun them with no noise whatsoever. Something with the wheels is not right and i cant figure it out.
    I have two videos of said noises. one with the summers on and one with the winters on. watch and you will see what im talkin about. any help would be great thanks!
    Summer rims with the click-click:
    http://www.youtube.com/watch?v=Qa8jfYxFODY
    Winters with no problems:
    http://www.youtube.com/watch?v=pBLgyxmpzVk
  • Liam
    • 753
    Lugs too long, hitting the parking brake assy.?
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      That sounds like a possible cause.
      • AndrewBird
        The Mad Scientist
        • 11898
        That was going to be my guess. Either that or a nail in the tire, but if it does it when off the ground, then...
        • danv
          • 25
          If you switch sides with the summer rims, does the noise follow to the other side?
